Can I easily switch between the Lite and the Full versions? The end users want to be able to use both for a while
Some additional information:
I know the different between the Full and the Lite but I want to run them together on one PC.
So that I can choose if I start the Lite or the Full.
The problem is solved. It's a setting in the install procedure.
