Creo View Drawing Compare
  • March 20, 2013
  • 5 replies
  • 10629 views
Creo View Drawing Compare.. seems like we took something that should be easy and made it very hard. Why can't I find the drawing I want to compare two seperate revisions or iterations of that I find on the details page with the history tab, select the two objects and choose open in CREO VIEW. Then In Creo View I should be able to do something as easy as select the two and pick a compare action.
What is the deal with adding to clipboard "and you cannot add them both from the history tab, it claims it adds them but it dosn't". You have to go to each of the objects detail page in order to have the drawings show up on the clip board. Now you have to go to the clipboard and select both objects and choose to open in Creo view.
Once you get the objects in Creo.. not very intuitive regarding the compare option or getting the overlay of the two drawings....
GregoryPERASSO
Hello
you should create an idea. I'll will vote for ...
regards
You can bring your idea here in "Ideas": http://communities.ptc.com/community/creo?view=idea
Hello
Could you please elaborate the process?
I could not able to compare the both revisions of the drawing.
If you give details step that would be appreciated..
GregoryPERASSO
From the history table, select 2 versions of the drawing and add them to the clipboard
Then go to clipboard, select the 2 versions and open in Creo View
In Creo View you cans now use the compare tool to superpose the 2 drawings ...
Carl, a workaround...as usual...:-)..is to start from the Clipboard click Add and search for the drawing. From here you can add two seperate revisions or iterations at the same time.
Note, I agree, it should be possible from the history tab and this is the most obvious place. The Compare information is pretty useless....great...by default I can see that the file size changed from 300 kB to 400 kB..
If you have the time though please submit the idea and I will vote for it.
Cari, I have tried options as you suggested, but I’m not able to view the drawings in single window, can we compare the drawings in CREO VIEW LITE?
If yes do I need to change any settings…?
In CREO VIEW LITE most options showing but they are not in active…Please help how to solve it..
Creo View Lite does not support comparison of 2D Drawings. Please try with Creo View MCAD.
canderson10-MarbleAuthor
Bottom line... great consept extremly poor execution. This is why the tool is not widely adopted and the many many enginers I pushed to use this functionality stopped because they forget how....
