Fixed dimension in sketch
I think beside "Lock" and "Strong" we should have "Fixed" for maintaining those dimension even scaling model.
If user set the dimension to be fixed nothing can change the value - at the moment I obtain similar result using relations, but it works only after regeneration, but fixed dimension will remain the same always until user manually not change it.
