Linked Data isn't Updating
I've got a Creo Illustrate 2.0 drawing. When I look in the S BOM, I see a subassembly shown as "abc.asm, -.3". When I go into the Tools menu and select Edit Structure, in the E BOM, I see "abc.asm, -.7". I see that many of the items in the E BOM up to and including the top level asm have higher "dash numbers" than in the S BOM.
How do I get the higher dash-number items from the S BOM to the E BOM? I've already done a lot of work on the drawing, so obviously I don't want to start over!
When I look in the lower panel and select Source, I see five pvz files. For all of them, the "Update policy" indicates "Update after confirmation", and "Status" indicates "Up to date".
Am I doing something wrong, or is there something I should be doing. I thought Updates were automatic (asking if I want to incorporate them).
