Publish Illustration files from Creo Illustrate 6.1 to Windchill
  • December 8, 2020
  • 884 views
  1. How to publish .pvz, .cgm, .svg illustration files from Creo Illustrate 6.1 to Windchill?– It is showing error – “Publishing to a server location is not supported.”
  2. My requirement is to save these files in Windchill.
Server side publishing addresses this by automatically taking the published contents and associating them to the representation.  You can also use the post-publish delegates to move them into separate business objects as desired.
I would suggest contacting your Windchill admin team to help set up the server side publishing.
