Report Engine
I'm setting up a report table with part numbers of the connector, wedge, terminals, seals and plugs. I see that there are 2 tabs in the Report Engine window (Report Table & Detail). The Detail tab I have figured out, from what I can tell it's reading the port parameters, but the connector and wedge part number are in the Component Parameters. I have search and read but can't find a way to get them in my report table. Putting them in the port parameters shouldn't have to be an option since they are tied to the component already, plus that means I'd have to edit all of my artifacts.
