In a Creo Illustrate Figure, is it possible to have a section view only displayed in the inset? I do not want the section view on the main parent model in the figure view, only the section view.
This isn't currently possible, as the inset is essentially just another camera looking at the main view.
So you will always see the same content in the inset as the main view.
This could be a good candidate for an Idea.
Interesting that this is the first image we see when Creo illustrate opens, the helicopter in the background not only shows a section with the panel but also an exploded view of an inside component. Is this already implemented/an open Idea?
