What is the way to view Creo Parametric simplified representations in Creo Illustrate?
is it possible to do it?
Can Creo parametric groups be viewed in Illustrate?
Ty,
Matteo.
When creating a new figure you can choose a viewstate to use as the starting point for the figure.
Simp reps will be shown under the Alternative Representations.
One thing to bear in mind is that currently when using a alt rep to create a new figure alternative representations of parts will not be loaded, instead the default representation will be used.
You will know if a default is being used in place of a alt rep as a warning message is displayed.
