11-Garnet
July 25, 2025
schematics
  • July 25, 2025
  • 3 replies
  • 414 views
How can I create a custom connector, such as a dual-port connector with both LH (Left-Hand) and RH (Right-Hand) variants?
I’m trying to build a similar connector but I'm stuck on a few points:
  1. How to create a dual-port – When I use a simple port, it only creates a single port and not a dual one. So, I’m wondering if I need to create a dual port first, since it’s not available in the default port options.
  2. How to replicate the behavior of the default connector setup – For example, when I select a default connector, a window pops up asking how many ports I want. I want to create a custom connector with the same functionality.
I've attached an image below for reference.
Catalina
Community Moderator
July 30, 2025
Hi @AK_10948685
Thank you for your question.
Best regards,
Catalina | PTC Community Moderator
I'm sure someone much more knowledgeable than me will come along and provide more insight, but I'll try to help.
You're wanting to create a variable connector.  My understanding is that these are created as a Group component.  When you create the new group, under the Group Properties window, you will need to make sure that "Fix member identities" is NOT selected.  This will give you the flexibility of choosing the number of terminals in your connector when instanced.
As far as the dual port goes....I simply use the same port on both sides of the geometry.
Hope this helps some.
Community Manager
August 5, 2025
Hello @AK_10948685
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
