Auto-remember previous constraints
  • October 8, 2015
  • 2 replies
  • 1553 views
Hello all,
We are trying to find the setting that basically allows the function of remembering constraints upon assembling the same component. I have seen it in the past when I assemble a bracket with 3 constraints, I then assemble the same part again and the placement has the constraints I previously used in place. Does anyone know the config setting to turn this on?
CC
you could use the repeat function
- mark your component
- RMB Repeat
- select which assembly constraints you want to set
- Add to the selection list
When you have placed all components
- Confirm
Reinhard
