CREO Simulate - Transfer CREO results to ANSYS
Good morning,
I would like to know if it is possible to transfer the results of a static simulation performed with CREO Simulate to ANSYS wor a following simulation which should start from those results (for example, perform a drop test simulation with ANSYS which includes pre-stresses obtained from a static simulation with CREO Simulate).
Thank you for the support!
Regards
