Checking in third party files that already exist in Cabinets
Hello, All:
We're still getting used to the new file system structure in Creo
2.0/Windchill 10, and we've encountered a new situation; we need advice on
the best way to handle this.
Our components are to be attached to a main frame that is being designed by
a third party. We have an assembly where the third party frame is the first
component, and we've put our components into the same assembly, but have not
used any references to said frame - everything is assembled using the
default assembly datums as the only references. We have received an updated
frame from the third party vendor and I am ready to check the new frame in,
but its components that already exist in our cabinets are showing a circle
with a line through it which, when moused over, says, "Modifications Not
Eligible for Upload," and a warning symbol that says, "Warning: This object
is modified but not checkedout."
There are a number of ways to handle this, and we would like to hear from
those of you who are experienced with this new system as to the best way to
fix our problem. The two methods we have thought of thus far are 1) have an
administrator log in and force check the components in, or 2) get a list of
the files (there are 823 objects, only 278 of which are new), delete the
existing ones from the Cabinets and delete the frame from the top assembly,
then check the new version in normally and reassemble the new frame to the
top level. I'm sure there are other ways to handle this, and am interested
in learning about any others that might be better for our situation, and
pros and cons of the two methods described above.
Thanks in advance for any practical advice offered!
Carol
efefefefefefef
Applied Research Labs
University of Texas at Austin
Carol Fly
Mechanical Designer
(512) 835-3397
Fax (512) 835-3259
efefefefefefef
Carol
efefefefefefef
Carol Fly
Mechanical Designer
(512) 835-3397
Fax (512) 835-3259
efefefefefefef
