Create beam assembly using beam idealisations in Simulate 4.0
  • December 15, 2023
  • 2171 views
Hi
I am doing analysis on a relatively large structure, and I would like to build the the model for Simulate using beam idealisations rather than native models.  I know how to create an individual beam, but am looking guidance/tutorial on how to create an assembly, if possible using a mixture of idealised beams and 'physical' geometry.
Thanks in advance
Francis
skunks
assembly attached
fward10-MarbleAuthor
HI, Thank you for this.  An interesting model. Is the connection between the beam section created by using a default bonded model?
skunks
"...default bonded model..."
I always use this mode.
