Creo 3 Feature Operations -> Copy-> From Different Version; Where is it?
tbraxton
In Creo 2 there is Feature Operations -> Copy-> From Different Version function available. In Creo 3 they have done away with this "redundant" UI but I can not find the equivalent command in the Creo 3 UI. I have an open call with support for 4 days with no documentation other than a CS document that says to use copy/paste for all feature copy ops.
So how do you copy from a different version of the part and have Creo map the common refs as is possible in Creo 2? If they are actually offering CTRL+C/ CTRL+V as a replacement for this I am not seeing equivalent functionality. I have to manually map every ref to copy a feature from one model to another, this is not an improvement to the functionality. Anyone have any additional information on this UI improvement?
Involute Development, LLC
Consulting Engineers
Are you meaning an older iteration number?  If so, try this:
  1. Open the older iteration.  This can be done easily by selecting the file name in the file open and adding the ".XX" at the end manually, where XX is the version you want to open. Creo will ask for a replacement name since you already have the file open.
  2. Select the feature(s) you want to copy and select Ctrl-C or copy from the menu.
  3. Return to the window with the latest version (dual monitors is very helpful here)
  4. Select the drop down next to "Paste" and select "Paste Special".
  5. In the next dialog pick "Advanced reference configuration" then OK
  6. In the next dialog pick"Keep dimension values" and OK
  7. The next box is where you pair up the references. Since these are different versions of the same feature, it should all be populated and all you need to do is hit the green check
Copy > paste special > advanced ref configuration is very powerful, I use it all the time to copy feature between models or even inside the same model.  I've never used copy > paste.
LinkedIn
StephenW
(To:tbraxton)
Sometimes mapkeys can find commands no longer available. You might try it.
name is diff. copy it to your config.pro and reload your config.  Worth a shot.
mapkey diff ~ Command `ProCmdMmFeatOper` ;#COPY;#FROMDIFVERS;
tbraxton
(To:StephenW)
Mapkey does not invoke the menu unfortunately.
LinkedIn
tbraxton
(To:tbraxton)
It took escalating the call and more than 3 weeks to finally get some documentation that explains what is behind the UI in this case. References are mapped but there is no indication in UI to show this which was quite confusing. Here is the best explanation provided to date that is relevant to this particular case of copy/paste functionality.
http://help.ptc.com/creo_hc/creo30_pma_hc/usascii/#page/pma/part_modeling/part_four_sub/Pasting_Using_the_Same_or_New_References.html
