Creo Simulation Live is too slow with RTX 3060
  • December 14, 2021
  • 3 replies
  • 3568 views
Hi, I have a PC with GeForce RTX3060 and I use Creo 4.0.
I borrowed a 30-day trial license of Simulation Live, but it is too slow on my computer
If I clik the simulation tab, it takes about 10mins to turn on and the simulation process also takes about 10mins.
Both of them should be done within a minute.
I asked the sales person about it but he just keeps saying "Simulation Live is not compatible with your graphic card".
I looked up the requirements of Simulation Live and found that it only supports up to Pascal architecture(GeForce GTX),but RTX is Ampere architecture.
I wonder if anyone has the same issue but has solved the problem.
download Creo Hardware Checker from https://www.ptc.com/en/creo-hardware-check page and use it to test your graphic card.
Also, earlier there were similar questions in some way:
Article - "What kind of changes should be made to speed up the process of a Contact Analysis running time and performance using Creo Simulate": https://www.ptc.com/en/support/article/CS101435
