Difference btw aestethic and technical surface?
Hello, I wonder what's the difference between a technical surface and an aestethic surface, the only thing I found was:
"The technology has encompassed two main fields. Either creating aesthetic (class A surfaces) that also perform a function; for example, car bodies and consumer product outer forms, or technical surfaces for components such as gas turbine blades and other fluid dynamic engineering components."
Can someone explain in a short version?
