3-Newcomer
February 1, 2016
Dinamic Frecuency response example
  • February 1, 2016
  • 2 replies
  • 1347 views
Hello , I need an example to simulate a Dinamic Frecuancy response as on CReo Simulate ADvanced Simulation Data sheet is written and  possible to be done , I tryed to obtain a(t) versus F( f Hz) as in PIC on data sheet is but it was not posible
any help??? , someone can provide me any simple example??? for this to be postprocessed?
Hello Oscar
It's not that hard, but you might require some training in dynamics.
I've got an example of such a graph here
You can reproduce that by running the analysis "Dynamic_frequency_example" from the mirror.asm model that I enclose.
When the analysis is completed you can make a graph of the only measure that is in the model.
Succes!
Erik
This was posted on the forum while back
Document on Pro Mechanica. WF2
refer to Chapter 13-41
Don't forget that there are excellent and broadly equivalent resources on the support site together with the model and first part of the example above.
Regards
