Hi All,
mthomas-4
Hi All,
Check the following circumstances for simulation diagnostics:
  • Examine Material Properties assigned to part, components or fasteners
  • Check Constraints
  • Identify connections between components or different types of meshes
  • For Load/Constraints definition select mesh points, not geometry vertices (select with RMB > Pick From List)
  • Examine Spring Element Properties
  • Examine Beam Element Properties
  • Identify if slippage can occur where Contact Regions are defined
