Licenses...
Greetings,
Are you familiar with the way PTC sends two license files - one is
called "standard", the other is not?
One is for borrowing a license and one is for running older versions -
you cannot have both...
Does anyone know which is which and what is considered an "old version"?
I don't need borrowing, but I do need to run WF2. Is WF2 old? (trick
question...) Will WF2 run with either license?
I rec'd both but they came without a description.
Thanks a lot.
-Nate
This email may contain material that is confidential, privileged and/or attorney work product for the sole use of the intended recipient. Any review, reliance or distribution by others or forwarding without express permission is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
Thanks a lot.
-Nate
