Material file database (again)
  • December 4, 2013
  • 2 replies
  • 9318 views
Hello all - I'm new to this group but a seasoned Pro/E designer and experienced Mechanica user based on Ireland.
I have a job on which requires me to finally get to grips with the new elastic-plastic analysis functionality of Simulate 2 and apply it to a forming operation on a small 300 series stainless steel tube. Would anybody on here be prepared to share a material definition file for one of these steels, set up with stress/strain data for LDA? I'm not trying to freeload and would be happy to work collaboratively and reciprocally with one or more knowledgeable users who may also also be working to develop confidence in this powerful new functionality.
Many thanks
Tony
Best answer by ehaenen
Hi Anthony
Just as long as you understand that this is a typical engineering approach to AISI 304, that works well in Creo2.
There is a lot to be said on how to correctly make a material definition, but this one works nice with Creo (Creo likes smooth curves) and fits the 304 data for yield and ultimate (with true strain of course!)
Try it, let me know what you experience.
https://drive.google.com/file/d/0BxuTvot6TxcLelVEZTdVdkk1UkE/edit?usp=sharing
Erik
Hi, Tony,
Here is a link on quaractéristiques of stainless steel.
I do not know if this is exactly what you want.
Cordially.
Denis
http://www.pxprecimet.ch/data/documents/fiches-techniques/FR/liste-complete-alliage.pdf
ehaenen1-VisitorAnswer
Hi Anthony
Erik
Eric here is an update about how I got on - and another question! (should I post this on a separate thread?).
I resolved my installation issues and familiarised myself with the advances in Simulate since Mechanica WF4.
I modelled my problem (the flaring of the end of a thin-walled SS304 tube) using bricks as far as possible, using an enforced displacement constraint, making the tubing workpiece short enough to avoid buckling modes, defining contacts with the mandrel by hand etc etc. and using 80 time-steps and single-pass adaptive converegence I got this:
Video Link : 4537
Not too bad I thought given the non-ideal nature of the way the mesh was generated using the available mapping tools. I should be able to define a composite measure for tracking engineering stress and strain as per Roland Jakel's "Basics of Elasto-Plasticity".
What is stumping me however is how to get the Include "Unloading function" to operate with my geometry, or to find a workaround. As Unloading seems to work with a single load reversal step, and as my part will be 'clinging' to the mandrel, Solver gives me: "Excessive motion detected at contact regions. Cutting load step size" during the final unload step, hunts for a workably-small load step and fails to converge. As a result I can't directly see the final plastic-only deformation of the flaring process.
Erik, if you or others have any thoughts how to workaround this (apart from manually subtracting elastic strain from measured engineering strain) I'd much appreciate it!
Tony
Anthony
Absolutely beautiful, great work.
I've done something smilar, but not as spectacular.
Unloading has never worked for me (the automatic way). Same message as you got.
I use an excel sheet that generates cam profiles. I always set the amplitude to one (1) and use the result as a scale factor for my load or prescribed displacement. That way I also scale it back to zero again.
My third picture shows a graph of 2 such curves (The blue one preloads the rubber block in my example, the red one drives the punch)..
It works!
Erik
And yes , maybe we start a new subject on non-linear analysis in general. I made several really cool examples... I'm a great fan, hope they keep developing the capability.
