Mechanism
  • July 1, 2021
  • 2650 views
Creo Parametric 7.0.4.0
we recently upgraded to 7.0.4.0, my older version I was able to move mechanisms by hitting Ctrl+Alt+Left Mouse which was very convenient this new version does not allow me to do this, is there a setting somewhere to fix this or is it gone from the new version?
Hello @sazzarello,
Thank you for reporting this behavior with Creo Parametric 7.0.4.0 on your machine.
I ran a quick test on  my machine with a simple mechanism assembly and I am able to use the CTRL+ALT+LEFT mouse button to move the bodies from my mechanism.
Please can you confirm that the Drag Component command is working with your assembly.
PS: I ran the test  without config.pro and without connection to Windchill.
Jean Claude
yes the drag component command works as it should
@sazzarello,
Thank you for your quick reply and confirmation regarding  the drag command.
Is this issue  specific to your machine or are you able to reproduce on a different one with Creo 7.0.4.0 as well?
As  I  mentioned in my previous comment, did you check without your config.pro, config.sup and without connection to Windchill?
Jean Claude
