Poor meshing results - Tesselation in Flow Analysis
I am getting very poor meshing results. Some regions are plenty of spurious holes where no mesh is defined, and I end up with many subfeatures. I believe this issue is a consequence of using a coarse tessellation, but I find no way of changing it.
In fact, the help does not mention the difference between "Simulation" and "Regular" tessellation. I have found that regular tessellation does not produce interfaces between contact regions and is, therefore, useless for heat transfer problems. While the regular tessellation allows changes in "chord heights" and "angle controls", the simulation tessellation does not. It gives a rather coarse result that I need to refine.
Please, help.
