Porous Surface on an interface
  • May 24, 2021
  • 1666 views
I am modeling a circuit for oil cooled brakes to evaluate the flow throughout the system. I don't have the detail for the brakes themselves but I do have some test data for flow and dP. I would like to represent the restriction of the brakes using the Porous Surface model on an interface. How can I determine the Thickness, Permeability and the Quadratic Coefficient? I have a representation of the brakes in the model with a certain length which I think I can use as the thickness. I need to determine Permeability and Quadratic Coefficient based on my test data. Does anyone have a suggestion? I was given a spreadsheet to find the Linear and Quadratic Drag Coefficients for a resistance model that was applied to a domain. I would like something similar to that for the porous surface.
Hi please refer to the CFA how to video series, there is one dedicated video to explain this topic. Thanks.
https://community.ptc.com/t5/Analysis/Creo-Flow-Analysis-How-to-video-series/m-p/707437
