Publish geometry & copy geometry
Hi, I am creating a top down design with skeleton models. I have created the skeleton and i have published the all the geometry references. Now in another part i want to copy certain geometries, but by default WF4 copies all the geometries which are published, can i able to select the particular refernces alone which are required to that part
Another doubt is i am not able to select the sketched datum points while publishing the references, it gives me the warning message as "You are allowed to select on target part only"
can somebody help me on this.
Suresh
