“Restart” Option?
  • August 20, 2015
  • 1043 views
Does Creo Simulate have a “Restart” option? For example, let’s say that I am running a static nonlinear analysis that takes place over the course of 2 seconds.  There are two Constraint Sets, Constraint Set 1 and Constraint Set 2. For Constraint Set 1, the time dependence is a linear function where the value goes from 0 to 1 with slope of 1 from time 0 to 1. From time 1 to 2, the value remains at 1. For Constraint Set 2, the time dependence is a linear function where the value is 0 from time 0 to 1. From time 1 to 2, the value goes from 0 to 1 with slope of 1.
What if, after running the analysis, I decide to change constraint set 2 (not the time dependence, but the constraint itself), but leave constraint set 1 the same. Is it possible to start my analysis at the time of 1, since I didn’t change constraint set 1? This is the idea of a “Restart” option that I mentioned earlier. Is Creo Simulate capable of doing this?
Thank you,
Steven
Hi Steven,
so what you ask, is for a dynamic time analysis:
  • You make changes to the loads, that have an impact not right from the start of the analysis, but somewhen at a later time step.
  • And you like to reuse the results from the previous analysis as far as it is unchanged and have Simulate start, at the step where the change becomes effective
Interesting thought!
I have never heard about such a function in Simulate, but maybe someone has an idea how this could be achieved?
Gunter
