Sections in family table
I have a generic part, with 3 instances.
In the generic, there are all functions, then instances are cast part, pre-machined, and machined part.
I have a section, that is made for machined part, which uses a plan passing through a hole.
This hole is at "NO" in the family table for cast-part and pre-machined.
So, the plan doesn't appear.
But the problem is with the section depending of the plan. It brings me an error because it doesn't find the reference.
When I verify the family table, cast-part and pre-machined failed.
It is not possible to had the section in the family table because it is not a function, but it reacts like one.
Do you know how to resolve my problem ?
