Size of legend window
- December 27, 2018
- 1 reply
- 7530 views
Hi.
Creo Simulate Live looks great and is very easy to use.
I only have one minor complaint:
I am using 27 inch monitor and 4k resolution. The size of legend in graphics window is really small.
The printscreen is in the attachment (size_of_legend.png).
The legend gets bigger if I change the Resolution of screen or Scaling factor. But I think that PTC should use some other method to control the size.
I also have a question:
I made a test on a complex model. And although the Performance Options were set to high (Accuracy), the results are still shown gridded. Why is that? Is it possible to set even higher Accuracy, so the results would be shown in continuous color (grided_results.png)?
