Spring in CREO 2.0 simulate
rhilson
6-Contributor
Hello, There are lots of issues here. I am trying to simulate a electronics chassis on a tray with LORD type isolators with the spring model. First, how do you make them visible in results. I cannot seem to see them. So run a static "check" simulation (1 G in one direction) and I get some results. The reaction check out, etc. I run an eigenvalue extraction. I get the model shapes (without springs) and they seem reasonable. I run a random vibration and I get the fatal error, saying that I have an unconstrained degree of freedom. The message continues that I should run a constrained Modal Analysis with rigid mode search to see the unconstrained degrees of freedom. Well, I did that and 1) I didn't have any rigid modes. (with the rigid mode option on and the lowest frequency to start the search at "0" Hz.  HELP. Any suggestions???
Thanks in advance.
spring to ground
creo simulate 2.0
rhilson
6-Contributor
(To:skunks)
 a belated thank you.
