how to using Creo MDO 3D contact
ptc-3977032
Such as pictures, 3D contact tool Get used to using.
I want to use the analysis.
Is caught flat surface.
As shown in the figure, the rotation of the surface modeling is not recognized.
Is there another way?
bp
(To:ptc-3977032)
3d contact can only handle flat surfaces connected to rounds (or datum points).
You have to define a flat surface on the cone, you can then hide the surface (which is not a solid).
tips:
- assign a material to all individual parts.
- Only assign 3d contacts where its really needed.
- regenerate before starting analysis
- use higher frame-rate for better results
I hope 3d contact will be a lot more user friendly in CREO 3..
good luck.
Video Link : 4650
