large gears are always incorrect and interfere?
For a new project Im going to waterjet cut two large metric spur gears (no I will not simply buy them).
The center distance will be (module 3 x 60 teeth) =180 mm (= both nominal diameters/2).
In Creo I've found out that these gears will actually interfere, See image .
Surely real gears dont have this problem, but since Im going to cut them myself, I will actually have this problem.
So whats going on? It doesnt matter whether I download a 3d model of a gear from a manufacturer or create a parametric spur gear myself (both using standard formulas), the interference is there.
How do I solve this? Should I create a cut on the spurgear (a small offset) to avoid interference? But then the contact point is not optimal anymore?
Any ideas?
