mechanism damping
Ive added a 3d contact in an assembly.
After each regeneration I see the following warning in the message log:
" Material STEEL_UNSPECIFIED does not have Mechanism Damping Coefficient defined. Used default value."
So I would like to get rid of this warning and I think if I edit the material properties of all the parts it will be solved, but I have no clue what value to fill in as "Mechanisms Damping"
Im looking for a decent value for a cheap construction steel. Any suggestions?
