restrict draft feature to add material only, not remove?
- September 28, 2011
- 2 replies
- 1332 views
One of our designers is working on a casting model and is trying to create a drafted feature set similar to the attached picture. I haven't found a way to get the draft function to do this and end up having to create what he wants with a weird kind of hackish combination of cuts, features to add solid material back and then drafting. Would surfaces thensolidifyingbe a better way to get this done? Any suggestions for using the draft function to achieve this?
Erik
(Wildfire 3 M250, Windows XP 32 bit)
