18-Opal
April 30, 2015
Anyone using Zuken E3 files?
  • April 30, 2015
  • 858 views
Anyone using E3 data in there manuals? We are embarking on a new adventure using these for our manuals. Looking for some info if you can keep the links working?
Bryon
18-Opal
May 1, 2015
I've never used Zuken E3, but if I had to solve this problem, I'd start by trying to find a common CAD format that both E3 and either Creo Illustrate or IsoDraw both understand. If you can get the data into Creo Illustrate or IsoDraw intact, then you should be in good shape to publish with links.
--Clay
