Community Tip - You can subscribe to a forum, label or individual post and receive email notifications when someone posts a new topic or reply. Learn more!
X
In the process of upgrading to Arbortext 6, I overlooked the fact that I need to recompile my old DTDs to support our prior editions. However, when I went to the Tools menu, "Compile Document Type" is not present.
Does anyone know how to get this back, or what the preferred approach is for 6.0?
Aah, it seems removing the old .pro, .ptd and .dec took care of it. Not that I'm complaining, one less step for deployment, but I guess I got used to having to pre-compile first.
You still have to compile SGML doctypes in 6.0. In any case, you can just type "compile_doctype [path to DTD]" on the Arbortext command line and it still works the same in this mode in 6.0.
Hmm, it seems that touching a blank template.xml file in the same dir fixes the problem. I have a case opened with PTC get their take, and will report my findings.
