Arbortext "KEEP too large - made empty column/frame . [1109]" error
JHollis
I am creating an Owner's Manual in Arbortext using DITA2.0 for one of our products.  It is in 5.5" x 8.5" format.  When I try to get the cover to do a full bleed (blue background), I get the KEEP too large - made empty column/frame error, and it stops publishing at the cover.  The document is approximately 100 pages.
I have looked high and low for information on how best to troubleshoot this and am coming up empty handed.
Any assistance or advice is greatly appreciated.
Arbortext Editor/Styler v 8.2.2.1
John
Do you have any tables on the cover? Do you have styler? if you do you can choose edit, edit resolved document, for styling. Then if you open the stylesheet from there, you can click through each element and see what is going on.
Bryon
Bryon,
Thanks for the info.  I have styler and have been through the resolved doc for styling.  Only thing I can figure out is something in the table is amiss, creating the error.  Dang if I can find it though.  I will keep looking...
John
Check if it is too wide for the page. We have had that when users modify tables column's and make them to wide  for the pdf publish.
Bryon
Bryon,
There was something in a table being created in Generated Text.  I never found out what the actual issue is, so we scrapped that whole cover and aree working to create a new cover without all of the generated content.
John
