Can you pass parameters to a macro
I'm used to a different macro programming language in which you can have 1 macro do several different things by passing parameter(s) along with the macro name - e.g. macro_name 'yes' The macro then declares the parameter(s) e.g. parameter yes_no The parameter yes_no is then a variable yes_no with a value of 'yes' The macro then uses this variable to determine an action later on. For example, I have a macro that changes a drawing and saves it down again, but I now find I want a very similar macro that does everything except save the drawing down again. With a parameter, I could include an if statement in the macro to either save the drawing or not depending on the value of the parameter. Otherwise I will have to either copy the macro twice or split it into bits and run as separate macros Is there something similar to this in Isodraw? I have looked but can't find anything, though the terminology may be different.
