Client composer returning 'Error response from e3: message = 'Error return '0' from PDF generator.'.'.
  • February 10, 2012
  • 1463 views
We just set up a new server to run PE 5.4. I can compose using our customized FOSIs but when I try to compose using LOGSA XSL files version 1.8, I get the following errors (The error log is very long so I just copied the tail end) See attached text file
I cannot figure out if it is a setting inthe e3config.xml file, java, or TOMCAT.
THanks. Allissa
    Hi Allissa,
    I don't recognize the error off-hand, so no direct help there. I suggest logging in to the PE server and submitting the composition request using PE Interactive which is essentially Editor on the server. You will most likely need to issue the following command from the command line in PE Interactive:
    set peservices=off
    That prevents PE Interactive from sending the composition request "to itself" over SOAP/HTML.
    Anyhow, the point of all this is that the error messages are MUCH more human-friendly in this environment. You may get very actionable results that way.
    Whether or not that helps solve your problem, you should join the Adepters mailing list where lots and lots of Arbortext users, admins, and developers hang out 24/7/366 (it is a leap year, you know!). Information on joining that list (as well as pointers to lots of other Arbortext resources) can be found here:
    http://blog.single-sourcing.com/top-arbortext-resources
    Good luck!
