In the previous version, I was able to search for tags with specific IDs. For example, I could search for an xref with xrefid "ABC". In 5.4 I can't find that feature anymore. It use to be under the Find tool in the menu bar. Did this feature get removed, or do I have to configure a certain setting or preference?
One more thing, make sure that in your tools/preferences/windows menu you have full menus clicked on. Else you will not see the tags for find that you are looking for.
Hi, I just opened 5.4 m100 and the find tag/attribute/value was there in the find pull-down and it worked as advertised. I have no scripts or ACL running that would make a difference.
What version of 5.4 are you running?
Ray
Hi Ray,
I'm running M030. Previously I was running 5.3, but we moved on to 5.4 when we finally switched over to Windows 7.
Ahh.... simple. I thought it might have been a preference issue, but didn't think to look under Windows.
Thanks for the help!!
