Documentum(6.7 sp2) WDK Adapter - A47521 - File not found Error Using Arbortext editor M060
  • October 21, 2016
  • 1005 views
When try to insert the  bullet or body in Arbortext Editor M060 using Documentum WDK Adapter . it is throwing the A47521 - File not found.
Can you please fix this issue on this.
Siva
mobile +919940678129
    If you mean Editor 6.0 M060, then that is out of support and you will not really be able to get assistance from PTC. If you mean Editor 6.1 M060 then you have until Dec 31 before support ends. If the latter, you should file a support ticket ASAP - http://support.ptc.com.
