EXTERNAL: SGML DTD to XML DTD
  • August 30, 2011
  • 2 replies
  • 814 views
Oops, I meant SGML to XML not vice versa. The idea should work either way, if it works.
    ebenton1-VisitorAuthor
    Instead of compiling as SGML, if an existing SGML document instance had an XML doctype declaration, the resulting error messages might still be useful.
    Never mind. I am full of it. This method would only work if both DTD's already exist and you want to fix the document instance. Duhhhhh.
