Error After Drag and Drop
JE_11013556
6-Contributor
Hi All, I'd want to seek for assistance if anyone knows why when I drag and drop the sgm file into arbortext, xml codes appear instead of text/tags. This is a Ukrainian language.
That typically means a doctype is not configured or available for the file you have loaded. Arbortext needs you to associate a doctype configuration with the files you work with, otherwise it falls back to basic text editing mode.
