I am working on my stylesheet with Arbortext Styler and it displays the following error message:
C:\Program Files\PTC\Arbortext Editor\doctypes\xhtml\xhtml.dtd
ERREUR Line: 30 Column: 11 Could not open file: http://www.w3.org/TR/xhtml1/DTD/xhtml-lat1.ent
I tried to get the file linked and I managed to download it without trouble... I do not understand what is not working, could someone give me a hand please?
This issue disappeared with the updating of my Arbortext licence
Sounds like something happened to your install. You might try reinstalling.
Liz
This is the 6.0 version and it has been installed for a while (almost one year) before the software begins to display this error message... I will try and see if it fix the problem
