German low quote mark
  • October 21, 2010
  • 642 views
Is there a way to type the german low quotation mark in ArborText. I have my language set to german by setlanguage=german but I cannot able to type the low quote mark. Do I need to use character entities for this?
Karthik
    Are you using an SGML or an XML basd DTD? SGML would require the entity,
    but XML should allow you to type it in or at the very least cut and past
    off the Character Map tool. For XML ths would also require that the
    encoding type in the XML declaration to be correct - one that allowed the
    direct entry of the character and not an entity reference.
    ..dan
    > Hello,
    > Karthik
