Highlighted text not being replaced
Has anyone had this problem? Whenever I double-click on a text element to edit it, the text highlights as it should, but when I type in new text, the highlight disappears and the new text is added to the existing text instead of replacing it. I have to click and drag to re-highlight the already highlighted text (which is not an exact science - if you miss the begining of the text by a micron, it jumps out of that text element and attempts to create a new one) in order to replace the existing text. This is fairly new behavior that seems to have started spontaneously.
