How can i insert a watermark while publishing to HTML Help ?
  • July 31, 2013
  • 1507 views
I have modified the stylesheet to include an underlay image in Page Region . This page region is included in Page Set . While Publishing to HTML Help I am unable to get watermark in the outtput file . However in PDF output i am able to get the watermark . What i need to modify in order to get the watermark in HTML Help output ?
Hi Swapnil,
I'm not sure about this one.
Your best bet, if you haven't solved this or moved on already, is to join the Adepters mailing list where lots and lots of Arbortext users, admins, and developers hang out 24/7/365. Information on joining that list (as well as pointers to lots of other Arbortext resources) can be found here:
http://blog.single-sourcing.com/top-arbortext-resources
See also:
http://www.single-sourcing.com/company/social.html
Good luck!
