How to enable lists within tables when importing into Arbortext
- July 30, 2014
- 1 reply
- 2207 views
I have developed an Import Map Template (MS Word to XML) which does not pick up any lists within tables from the source document. All other lists are correctly recognized. To remedy this issue, I set the "include lists" option in "initial preprocessing options" to true. This resulted in lists within tables being correctly recognized by the Map Template Editor, however when using the Map Template to import the Word file into Arbortext Editor, all lists now restart after every list item.
For example, where you would normally have 10 listitems within an bulleted list, there are now 10 bulleted lists with one listitem each. This error occurs in all lists. I've included screengrabs of how it looks in the source file pane, and then the results in Arbortext Editor. So in summary: For the Map Template to pick up lists within tables, I enabled "include lists". However, now all lists refuse to have more than one listitem.
Any advice on how to how to fix this would be greatly appreciated!
