I used to use Perl in APP-over-rides to output debugging information to a file like this:
formatting.evaluateShowString("\"junk\"$^[perl open(TMP, '>>c:/temp/debug.log'); print TMP 'specific-use: " + currentNode.getAttribute("specific-use") + "\n'; close(TMP);]");
This appears to no longer be working. But was pretty "hacky" anyways. Is there a cleaner way of outputting debugging information to a file or log somewhere?
Richard Steadman
Hello Richard, FYI Perl support was removed from Editor a few versions ago.
Bryon
Hi Bryon,
Thanks! My understanding was that it was no longer included by default, but you could add it back in (which we did).
Richard
Ok, I sorted it out.
This particular help page shows how to create external log files (or even write to the Styler Event log):
Quick summary:
var log = application.logs[5];
log.open(1, "C:/temp/styler.log");
log.write("Attribute" + currentNode.getAttribute("test") + "\n");
log.close();
var eventLog = application.logs[1];
eventLog.write("test");
