Image alignment problem in gen text
  • May 9, 2013
  • 2 replies
  • 879 views
Hi Adepters,
I recently upgraded from Arbortext 5.2 to Arbortext 6 and converted my stylesheets. I'm using Styler.
I've got a small image in a table in generated text and for some reason when I publish to PDF, the image is right-aligned in the table cell. In the Edit window it looks left-aligned. The cell alignment is Left and the left margin for the cell is 0. If I put text in the same cell, the text is left-aligned.
Does anyone have any idea why the image is appearing right-aligned and what I can do about it?
Carolyn
    I don’t know why your image is right-aligned, and neither do I know much about Styler. If I were using FOSI I might try wrapping the graphic in pseudo-tags and then apply left-align to the pseudo-tags. I don’t know if you can do that in Styler. Probably not. Sorry, but that’s all I got.
    Is there an Element in Styler for <graphic> or whatever your image element is named? If so, check its alignment. If not, try creating one and specify the alignment you want.
    Good luck!
    Suzanne Napoleon
    www.FOSIexpert.com
    "WYSIWYG is last-century technology!"
