I have ISOdraw M60 on an XP machine and it works fine. I recently upgraded to a new machine with windows 7. I went throught heprocess of reconfiguring my lecenses and installing isodraw onto the new machine. When I open the applicaiton, I get the error message "License request fail for feature ISODRAW".
Can anyone provide assistance to correct the issue?
Swri
Hello!
At computer change it is necessary to reconfigure a licence file (thus it is necessary to specify new (!) MAC the address of a network card). What type of the licence you use?
If the problem proceeds, you can create a new Case for service of technical support PTC, here: http://www.ptc.com/appserver/cs/case/case_logger.jsp
Ken
First, make sure the license is valid - run the ptcstatus.bat and/or check the debug log file.
If it's, then check the PTC_D_LICENSE_FILE environment variable value.Should be 7788@<host_name>
Where can I find ptcstatus.bat and the debug file?
Ken
ptcstatus.bat is under the flexnet\bin folder
ptclmgrd.log license log file is under the flexnet\licensing folder
Thanks for hte help. It was usefull information. IN the process of running them I realized that I picked the wrong software version for my license. Once I got the license that matched my version, everything is OK.
Again thanks for htehelp.
