IsoView: CGM graphics, raster content is "shuffled"
When viewing CGMs in IsoView, at the default size, which sizes the graphic to the viewport, the raster portions of the image is all shuffled. Horizontal portions of the image is "shuffled". If you zoom out to about 50% of the viewport size the graphic looks correct, but none of the text is legible because the graphic is zoomed out too far.
here is how the image is displayed:
Here is a similar portion of the image, how it is supposed to look:
(the drawing of the plane is a raster image imported into the CGM, while the black arrows are vector elements in the CGM.)
All the vector elements are positioned correctly, but the raster portions get shuffled depending on the zoom level.
This is using the 7.2 evaluation copy of IsoView and being used in IE7. The problem also occurs in IE8.
This problem only to select computers, but all running the same OS (Windows XP).
The graphic will look correct on some computers, whereas on others it will be incorrect.
The presence of IsoDraw does not affect the outcome either. Two computers running IsoDraw both have different outputs.
Has anyone encountered this problem before?
